Help finding best subs for $2000
Username: Avp689
Post Number: 7
i plan on spending $1000 on an amp and then $2000 for a subs can someone give me some specific suggestions of subs that would sound clear and be loud if i wanted them to be...im thinking about either The Rockford Fosgate T30001BD or an orion 2500d and i would like 3 subs...please some specific suggestions would be helpful so i dunno if im better off getting 2 12" 3 12" or 3 10" can someone please help me out
Username: Killer44
Ontario Canada
Post Number: 118
jsut answered it for u in the other post...lol
Username: Subfanatic
Walton, Ky Usa
Post Number: 168
go with 2 15 inch xx.x or 2 15 inch eclipse ti or ti pros....that will hopefully be cheaper than 2000 and you could buy a usa amp to power those bad boys
Walton, Ky Usa
Post Number: 169
http://www.woofersetc.com/product.asp?0=279&1=285&3=1613 for the 15 inch ti's
http://www.woofersetc.com/product.asp?0=279&1=285&3=1918 for the 15 inch ti pro's
go to www.reaudio.com and get the phone number for the xx.x's and you can order them that way..this is just one guys oppinion....good luck let us know what u end up with man
