Head deck distortion at low levels. HELP
GlenCox
Hi, I have a panasonic head deck CQ-C1300W head deck and I can start hearing distortion at just over half way, the volume goes from 0 - 40, and it starts sounding distorted at about 25 - 30.
I thought it may just be my speakers but it is distorting on my subs aswell which are running off a seperate amp. Is the head deck the problem? does the signal start getting distorted when turned up just over half way?
Any help is appreciated.
y
are u runnin a amp for ur in car speakersers if so check to see where ur rca's are runnin if there runnin with ur amps power wire that could be the cause of the distortion
GlenCox
No the speakers are not running off the amp, they are running directly off the head deck.
Username: Geekbike
Post Number: 36
Are you running the stock speakers? They may not be able to handle what your HU is putting out
Check your gains to see if they are properly set. It might be clipping causing the distortion in the subs.
Username: Yamahaboy
Orland Park, Illinois USA
Post Number: 42
he said his subs were distorting too...im having the same proble with my alpine type S's (i think thats the type) but i dont know what its doing it...other people said its the head unit "clipping" but i don't know
