2 or 4 ohm, single or dual voice coil
Username: 7mm_shee
plan on running 4 8" subs and was wondering whether to go with 2 or 4 ohm, and should i get single or dual voice coil subs, i am wanting some tight bass
Username: 7mm_shee
anyone
Username: Solacedagony
New Jersey US
Post Number: 250
What sub make/model are these and what amp are you planning on running.
Username: 7mm_shee
thinkin maybe some rockford he2's or hx2. and an orion amp, not sure which models to go with, any input would be appreciated, what should i look for on these, new to this but i know i want 4 8" subs in sealed box
Username: Taylor17
Kopperl, Texas
Post Number: 390
Better to git the 2 ohm dvc, depending on the amp, it will usually put out more power at 2 ohms.
