Do i need a new altanator.
Username: Urga21
West jordan , Utah Usa
Post Number: 10
I drive a 96 GMC sonoma four wheel drive extended cab and i want to put 2 RE xx.x with a hifonics colossus amp in the truck. I was wondering if i would need a new altanator or if the stock one would be fine. Also what battery would you suggest.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 52
how many watts RMS are the amps? .. i would imagine if your running 2 x.x.x subs you would have at least 2000 watts rms total... so you would need at least a 200A alternator... and i would get at least one optima yellowtop if not 2 ... hope that helps
Username: Taylor17
Kopperl, Texas
Post Number: 386
More than likely you'll need a new alt!
Try 4alterstart.com
