RE subs and colossus amp
Username: Urga21
West jordan , Utah Usa
Should i go with 2 re mt subs and the colossus amp or three triple x re subs and the same amp. what do i need to stop my truck from dying, like a capcitor or what.
Username: Urga21
where can i get some new re subs for a good price.
Username: James1115
Wilton, Ct
Post Number: 523
www.reaudio.com
you need a new alternator if you are planning on running 3200 watts. A very big one or even two. that amount of power isnt a joke. Is this going to be a daily driver or strictly comp vehicle. If it is a DD then you have alot more to worry about then your subs and amps. More like upgrating your entire electrical system adding batteries,Alternator's 0 guage wire power/ground. Re grounding your alternator,Engine block,battery to chassis with 0 guage.
Username: Invain
Michigan United States
Post Number: 400
Uhh. Your first your gonna need a very very big alternator to stop your truck from "dying." Second, RE subs are gonna be hard to find other than ordering them from the company. I think there is a couple sites that sell them, forgot the names, but a lot of times they are on back order.
Username: Hdubb
Farmington, Nm Usa
Post Number: 586
with that amp either get 1 15 Mt or 2 15 XX.X that isnt enough power to properly power 2 Mts
