2.0 cu ft
What sub do yall recommend for the best spl and sq from a seald 2.0 cu ft box.
Preferablly a 12". Also price isnt an issue really
Username: James1115
Wilton, Ct
Post Number: 397
well it all depends on what you are going to be running it with?
Well i will be buying an amp and sub at the same time with my income taxes. But i have since decided to go with a ported box.
Username: James1115
Wilton, Ct
Post Number: 435
ok how much do you want to spend and are you still staying at 2.0 cu/ft? Just asking because ported boxes need to be larger then sealed.
ok the trunk is pretty small, Its on a 95 dodge neon. And i will do a 2.5 cu ft ported box. i have 600 dollars to spend on the sub and amp
