JL Audio 15" W4 D4
Username: Sniperman
Michigan United States
Post Number: 24
I have 2 JL audio 15" w4 d4's and im trying to do some research on the specs of them. i havent found out what the rms on them are or what the peak power on them are. If anyone can post a link or tell me personally how much power should be run to one of these things to sound great that would be awesome.
Username: James1115
Wilton, Ct
Post Number: 393
http://jlaudio.com/subwoofers/pdfs/15W4_BDS.pdf
Username: Sniperman
Post Number: 26
So the rms is 200 watts but how many watts do you think it will take to power these to their fullest potential? Im looking for an amp to power one. I dont know how many watts to put to that one sub, and thats what im trying to find out from people with experience or just knowledge.
Username: James1115
Wilton, Ct
Post Number: 410
Well 200 watts will make that sub reach full excursion in the right enclosure. 150 will do it as well in a slightly larger enclosure. I would do 200 watts in a 2.25cu/ft sealed for SQ or 200 watts in a 3.75 ported for more SPL. As far as a amp lok into something that is 50x2 rms @ 4 ohms and 200 x 1 @ 2ohms bridged mono, or find a mono amp that is 200x1 @ 2 ohms.
Username: Sniperman
Post Number: 28
200x1 @2 ohms will power a sub thats 200 @4 ohms??
Username: Jmloughrey
Farmington, CT
Post Number: 904
...thats one low powered amp lol
Username: James1115
Wilton, Ct
Post Number: 413
yeah it is I was thinking the same thing when I was posting it. I didnt even know if they made mono amps that small so I was skeptic about saying it! lol! But to answer your ? you want it to be 200 x 1 at 2ohms not 4ohms because your sub is dual 4ohms and that will present a 2ohm load or a 8ohm load to a amp. Do you really want to +
-know what I would do! (prob not but I am gonna tell you) I would run that sub at 8ohms by a 400 watt 4ohm mono amp or a 200x2 amp at 4ohms. That way you have head room for later upgrades and you wont have to buy a new amp.
Username: Sniperman
Post Number: 29
why run the sub at 8 ohms? will it have better sound quality if i do it that way? so i wire the voice coils in series to present an 8 ohm load to the amp, then what amp can power 200x1 @8ohms?
Username: James1115
Wilton, Ct
Post Number: 455
you will be running the amp alot more efficiantly. Which in turn = less THD(total harmonic distortion)try and amp that is rated at about 400x1 at 4ohms= 200x1 @ 8ohms. will work nicely for you. Again if down the road you want to add another one you will have large amounts of unused power.
