Kicker L7 Break in
Username: Kumanan
Post Number: 13
How do i break in my Kicker L7?
how long do i play it on low power?
Um the technician cranked it up for a bit when he was setting the gains and stuff, so is that bad?
also, there is a input sensitivity on the amp that makes the sub have more pounding, should i set it to that? i got a clarion 1001.1dpx amp doing 1000 rms into the kicker...
Username: Taylor17
Kopperl, Texas
Post Number: 352
Just don't turn it all the way up for a few day's, and you will be fine. Around 15 hour's should do it.
Username: Rick_mcfarland
Palm desert, Ca Usa
Post Number: 38
i believe kicker recommends 22 hours or something close to that.
Username: Kumanan
Post Number: 14
the tech cranked it all the way up for about a minute though.. is that bad? he did it so he can set the gains
Username: Xxkmfdmxx
FL USA
Post Number: 284
Nah, Thats fine.
