Interfire Amps
BOOM BOOM
Tell me are InterFire amps any good? I have a local sound shop that has a 1000x2 for $300 is it worth the money
Username: Subfanatic
Walton, Ky Usa
Post Number: 123
i have an interfire IB2900C amp and it hits alot harder than its rated power and i have never had a problem with it...and i was just wondering if you could help me as well...i had it running to kicker comp vr's and im going to make it run a DVC Eclipse Ti but i dont know if this amp is 2 ohm stable...could you please help me...and what model are you looking at?
Username: Invain
Michigan United States
Post Number: 369
Didn't you ask that question a while ago? Yes it's 2 ohm stable, I don't think there are many amps that aren't. It's usually when you start getting into 1 ohm situations that some amps can't handle it.
Walton, Ky Usa
Post Number: 124
yea i did joe...thanks lol...i just get confused easily...but how would i wire my sub then... it kinda confuses me as well lol
