A box for 1 Shiva
Username: Vwbug1971
Warren, Nj
Post Number: 18
I could build one but i'd prefer to buy one. What would be the best box i could buy for one shiva and where could i buy it?
Username: Hdubb
Farmington, Nm Usa
Post Number: 530
you could get a small q logic box if you want sealed or if you hunt around enough on www.adireaudio.com you will find specs on several boxes for the shiva. if you do that just have home depot cut the wood for you if you dont trust your cutting skils.
Username: Drumjunky
Boulder, Colorado
Post Number: 57
also, www.acoustic-visions.com makes enclosures specifically for the shiva. They range from $120 to $410 depending on the size, type, and cosmetic additions to the box
