What amp to get for my 2x Type-R's
phea
Im getting a major hookup from a friend of mine at circuit city. I can get Infinity amps and Polk Audio amps for sure. Not sure what else they have but these seem to be enough to power my 12's. But I havent heard much from these amps so I wasnt sure which would be good for quality/price.
Infinity
1210A - 854W RMS x 1 4 ohm for $240
610A - 456W RMS X 1 4 ohm for $180
Polk
C500.1 350W RMS x 1 4ohm for $185
I was thinking of getting the 1210A and hook both my subs up in para., that seemed to be the cheapest setup to power both subs. Im fairly new to the audio sceen so any advice would help. Thanks alot!
Username: Kklagge
Post Number: 56
What ohm are the type R's? You could get an Audiobahn A8002T and run 400RMS@2ohm to each sub (if they're 4ohm DVC). I know alot of people on here don't like Audiobahn (i think their speakers and subs suck too) but I've had very good results with their amps. Just my $.02
Username: James1115
Ct
Post Number: 329
can you get two of those 1210a's by any chance?lol that is a nice amp should work for you.
