Bandpass vs. Ported
Which gives out more bass a bandpass box or a ported box?
Username: James1115
Ct
Post Number: 280
bandpass but they are much harder to build and they must be built properly and to spec or the bass will resonate and sound like doo doo.
Username: Jmloughrey
Farmington, CT
Post Number: 884
just build a ported box...
Username: Bdb_86
Bemidji, MN Usa
Post Number: 228
i would go with a ported box as well even if you were plaining on buying the box i would still go with a ported
Username: Insearchofbass
Post Number: 1036
LOL doodoo.. but hes right bandpass can be louder if built right i have a program you can use if your intrested to build one but ill recommend you do it all wood no windows because windows flex
Post Number: 1037
ps... you could build the wood plate where the window would normally go that would be removable so that you could get to the sub but make sure its a tight seal
