Alternator Upgrade?
Username: Nickb920
I have a 1997 Chevy tahoe and i just purchased a Hifonics BX1500d which i will be running at 1ohm 1500 watts. I have a 1 farad Monster cap. Will i need to upgrade the alternator and if so how much does that cost installed?
Username: Carguy
Post Number: 1236
You might want to contact your Chevy dealer for the stock alternator's power rating. It's probably somewhere around 75A - 80A. I see you got fooled into buying monster cap. It won't do anything for a weak alternator. For the future, you only need 1F capacitor per 1000W of peak power.
You will need at least 150A HO alternator. They usually cost anywhere from $200 - $350. Since you have a Chevy, American car, it might be cheaper.
Try 4alterstart.com for prices and models.
