Wat kind of speakers
Username: Seineil
wat kind of speaker is bested runned in a trunk a of a a4 2 ten inch or one 12 inch I was thinking alpine type R or the jlw6v2 what would give me the best sound quility
Username: Hydro
Post Number: 95
Dont really understand what you said but JLw6v2's are alot better than the Type-R's
Username: Seineil
I mean like wat kind speaker should i put in the trunk of my a4. wat speaker and how much of each would be best for sound quality
Username: Hydro
Post Number: 104
The Sound Quality of one 12w6v2 will blow away 2 Alpine Type R's as for SPL it might be close but why buy a sub with no sound quality and just SPL when you can get one with both.
Username: Seineil
wat is better for subs being placed in a car trunk(audi a4) 2 ten inch or one 12 inch
Username: Glasswolf
Post Number: 1113
What type of music do you prefer?
what will you be using for an amplifier for the sub(s)?
what is the rest of your system comprised of?
what is your budget for subs? an amp?
answer these, and I can offer some ideas
Username: Seineil
i listen to rap and hip hop but pretty much all kinds of music
amp orion or jl audio didnt by it yet still researching
two 10, 2 channel amp
or one 12, mono amp
my stock deck
type r seperates
not really a budget
but ill say under 1000
Username: Glasswolf
Post Number: 1119
use two 12W6v2 subs, and a JL 500/1 amp for them.
Username: Seineil
or one 12, mono amp
my stock deck
type r seperates
not really a budget
look seineil, if you stop listening to that rap bullsh it, then maybe you would spell "what" right. Thats right, its spelled what not wat. You dumb bastar d!!
Username: Its_bacon12
Post Number: 139
..........we need to restrict anonymous posts glasswolf, there may be an idea for you in the future
That person who posted the message under Anonymous isn't the same person as the one in the Thump thread. Look at the sentence structure and poor grammar as indications to an identity.
here here i am also anonymous and i didnt post that
I bet its one of the people with member or user names who don't want to be singled out or criticized for there lack of restraint and courtsey towards others. To the other Anonymous out there, I listen to that "rap bullsh it" as you call it and I don't come around here dissing NSYNC and 98 Degrees and try to piss you off.
