Every1's system
Username: Cenus
Hicksville, Ohio Usa
Post Number: 12
i just wanted to know what kind of system every1 has like the head unit, speakers, amps, sudwoofers, here is mine
HU- jensen cd335x
Speakers- kicker
Amp- kicker kx 600.2
Subwoofers- 2 12inch kicker cvr in a ported box
Username: Taylor17
Kopperl, Texas
Post Number: 216
If they are registered, just click on there name!
Most people list what they have.
Username: Rob315
Syracuse, NY U.S.
Post Number: 27
lol
Username: Hdubb
Farmington, Nm Usa
Post Number: 494
is hicksville a real place.
anyway my system is still in the crappy stages sooo...it will be upgraded soon, im looking at a nine.1 amp, memphis components, an alpine amp i thkn its the mrp-v250 or something like that,50 bucks? adireaudio brahma 12 and my decent basic kdc-205 kenwood deck. but right now it is a pile of crap, except for my brahma, but i blew my amp and i have nothing to run it so it is a paper weight :-(
Username: Wojopro
Silverdale, WA
Post Number: 172
Just click my name... Dont have much yet... Getting there! Buying a lil at a time!!
Username: Rob315
Syracuse, NY U.S.
Post Number: 35
stan what amp you running the 3 type r's on? im trying to buy a few more myself. right now i have 2 12" type r's and 2 mrd m501's. but its all brand spankin new sitting in a cabinet cause my headunit didnt come...i think i got ripped off! those f*ckers.
Username: Wojopro
Silverdale, WA
Post Number: 177
A really crappy RF... Dont know what model sorry.
Username: Insearchofbass
Post Number: 1029
alpine 9805 deck
mtx 275x amplifier running 85 x 2 on fronts mb quart 5.25
mtx 2150x running 120 x2 on rears mb quart 6x9
mtx 81000d running 1500 x1 on two real lanzar dc 12's before they went under and pyramid made them junk
all amps and neon lights hooked to toggle switches in center console and one switch as a kill all power. Amps mounted on plexiglass amp rack with two 10 in. blue neons under the amp rack
box is 3.40 cf useable both sealed and ported adjustable so ported i can pick my tune frequency
Username: Hdubb
Farmington, Nm Usa
Post Number: 509
hey sean can i see pics of that box. if you have any. sounds like a very interesting box.
Username: Rick_mcfarland
Palm desert, Ca Usa
Post Number: 26
I would also like to see that box. Dustin, if you want to see what I have just click on my name
Binny Del Bedo
two 12" barics...kx1200.1....ported....the works and a lady to deliver a complimentary BJ from time to time
Ya hicksville is a real place becuase it is about 10mins from where i am Paulding! hey dustin did u get your stuff from the wholesale?
Username: Cenus
Post Number: 13
no i went to toledo and got it at car stereo 1 they had a sale that i couldn't pass up
Username: Sploosh56
Ohio
Post Number: 496
They have 15" L5's on sale for $185. I saw that last night when I was there.
Post Number: 1033
sure ill see if i can take some pics of my box with my digital cam for you guys. If you want an explanation in the meantime its a standard subwoofer box but in the back board i have two small square windows then we mounted a internal wood support plate to mount to with screws and created a flush mounted plate to install in these locations. One set of plates were simple sealed plates and the next set had 4 in. holes cut carefully so that the pvc port tubing of various lengths could slide in and slide back out if needed to place a different port in (i have plans for an adjustable box in the future also for in car use that i can adjust the cubic feet and do testing)
Username: Adampit
Post Number: 7
In my 1996 Maxima
- Alpine CDA-9835
- Alpine KCA-420i Ipod Adapter
- 15GB iPod
- Four 6.5" Infinity Reference 6002si Speakers
- Two JL Audio VR075-CT Tweeters
- Alpine MRP-F240 50x4 Amp
- Two 12" Alpine Type R Subwoofers
- PPI PCX2125 500x1 Amp
BabyBrock
2001 Ford Explorer Sport
-Alpine CDA-7998
-Infinity Kappa 572.5 cf 6x8 for fronts and rears
-Infinity Reference 7541a 111 x 4 Amp RMS
-Resonant Engineering MT 12" dual 1 Subwoofer
-JBL BPx-2200.1 Crown Amp 2480 x 1 RMS @ 4 ohms
-All Monster Wiring
-Snailshell Enclosure for Subwoofer
-Stock alternator and battery...lol
Username: Kickercomp
Tampa, FL USA
Post Number: 69
1998 ford explorer
-pioneer 6500 deck
-4 total mobile 6 1/2s
-4 total mobile tweeters
-total mobile 400watt 4channel amp
-svr main car battery
-two optima red tops in back seat
-JL 1000/1
-13w7 Ported
