Door speaker install
how the h.e.l.l. do you take off the window crank of a 2000 sunfire? my last install had power windows, now its a whole new chalenge with a window crank. I know its a stupid question but someone help!!!
Username: James1115
Wilton, Ct
Post Number: 901
you need a special popper tool. Go to auto zone they should have one.
Username: Hdubb
Farmington, Nm Usa
Post Number: 750
look real close for clips too. lil o rings or something. then take those off and it should be easy
Username: Xxkmfdmxx
St. Petersburg, FL USA
Post Number: 336
I took mine off with a pair of needle nose plyers. Seemed to remove the clip holding it in place quite well.
