Does anybody know about this?
Username: Kenny_hammond
Post Number: 21
WHich subs should i get to put in a ported truck box ma audio jl audio or v max?
Post Number: 22
or audiobahn
Username: Solacedagony
New Jersey US
Post Number: 232
JL is, by far, the best choice in that category, obviously depending on which sub series you're referring to. Don't limit yourself to only those companies though. Tons of good equipment out there.
Post Number: 24
well dude i am not a person who knows to much about the bass part so can u recomend some that will fit in a Q logic type 2 box please!
Username: Byrumjr
Post Number: 45
Unless you have a cross over in your system. I like my subs under 500 Hz frequency and dual voice coils @4ohms. I like a lot of bass and the DVC @4ohms gives you a few ways to hook it up. I like them @2ohms pulls more from the amp. Just something to think about.
Username: Taylor17
Kopperl, Texas
Post Number: 217
Do you want sq, spl, or both?
Jl is a top brand, so out of that list, go with the Jl
Username: Rick_mcfarland
Palm desert, Ca Usa
I aggree with taylor. The jl are the best brand out of that list. look into eclipse they are amazing.
