HHHHHHHHHEEEEEEEEEEEEELLLLLLLLPPPPPPPPP!!!!!!!!!!!!!!!!
Username: Not_sure
Florida
hey, i'm lost right now. i have one DUAL 2 Ohm Voice Coil sub and a 2000 watt amp (1000W * 2ch @ 2 ohm) what is the best way to wire these up to get the best performance??? the amp is bridgeable to mono. can i run a 1 ohm load, or is that too dangerous??? what is the lowest safest inpedance i can run w/o destroying anything??? how should i wires the speaker??? i just need help period, lol.
amp:
max power output @ 2ohm: 1000 * 2 = 2000W
power output @ 2 ohm: 400w * 2ch(800W)
power output @ 4 ohm: 250 * 2ch(500W)
bridged power: 800W @ 1ch
channel seperation: 55dB
frequency response 1.0dB: 15Hz~30kHz
HPF: 50Hz~1kHz
LPF: 30Hz~250kHz
adjustable sensitivity range: 0.1-1V
input impedance:
low level: 10k ohms
high level: 100 ohms
speaker:
Dual 2ohm voice coil
1600W peak power
Username: Rob315
Syracuse, NY U.S.
Post Number: 30
what kind of amp is it?...and your only getting 400w *2ch@2 ohm.
