AI-NET???
Username: Rodolfo
Post Number: 22
I just purchased an Alpine eq and it has ai-net. What is this ai-net and does it eliminate the need for rca cables from the head unit to the eq if I use the ai-net cable? My Alpine head unit comes with ai-net also. Probably a dumb question but I didn`t get the manual with the eq and the manual for the head unit doesn`t explain what the ai-net`s function is.
Username: Xkawn
Post Number: 74
it is to hook up something with rca's to your cd player. for instance an mp3 player, a vcr/dvd player, mini disc player, game system, etc. here is the link i found the info on.......
http://www.logjamelectronics.com/piealpairca.html
Username: Xkawn
Post Number: 75
p.s.
here is a quote via alpine.
"The Ai-NET system links high performance components via a high-speed bus, providing greater sound quality and control convenience, plus easier system upgrading.."
sounds like it's also a way to link alpine stuff together
Username: Vinnyqh
Portland, OR
Post Number: 29
Yeah, it is used mainly for aux input and cd changer control.
