Vega
3vega12
I have 2 Cerwin Vega VMax 15' SVC runnin at 4ohms. About how many watts would this Vega mono amp put on one sub because im thinkin about buying two. Please help out.
The amp is Cerwin Vegas EXL 1000D
1000 watts Mono into 2 ohms
@ less then 0.1% THD
Vega Bass! Boost Control
High Current MOSFET power supply
Durable Mil Spec Glass
Epoxy pcb
Audiophile Grade Audio Components in Signal Path
Variable 12dB/oct Highpass/Lowpass Crossover
The answer is yes!! Cerwin Vega does make a 15 inch subwoofer!! So your in luck
