Which brand in my price range?
davidmorgan
ok i know this should go in the speaker section but i cant get any reply in there and i know more ppl read the subwoofer section so here goes .. im looking to buy new speakers for my fronts and rear in my explorer. its a 6'8 oval and 5 1/4 round speaker. I'm looking to spend a little more than $100, but i have no idea what brand or model. any suggestions. I want something with strong highs so my W7 doesnt drown them out and u cant hear the words because thats what its doing right now. thanks
davidmorgan
sending this to the top
jigga666
100 on highs and you have a w7?hahahahaha...ok
Username: Solacedagony
New Jersey US
Post Number: 195
You can usually find the Infinity Reference or the Infinity Kappa coaxial speakers at most places.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18800%26item%3D5745471999 &tc=photo
If you don't have anything useful to post, don't post.
Username: Jmloughrey
Farmington, CT
Post Number: 834
yea your best bet would probaly be to get some infinities or save up a touch more, if you skimp on your components you're stereo will just sound like trash...
