Good Fit?
nolimit182
Alpine MRP-M350 200W x 1 with Alpine SWS-1242D Dual 4-ohm 12", i haven't dealed with alpine before, i had an mtx 10 which hit really deep before, and im lookin for something liket hat. Would this be a good set up?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 118
yes it should work fine the amp will give close to 300amps while driving its rated at 350 for 14.4 volts get a ported box or make one if you want deeper bass
nolimit182
oops, i meant to put SWR-1241D Type-R Series Subwoofer with the amp
Username: Rzarector
Post Number: 121
still will work well the Rs can be overpowered if u want to upgrade your amp but that amp should work fine
nolimit182
alrite how about the mrd m300 or the mrd m301 which would be better
Username: Rzarector
Post Number: 126
the mrd m301 would be better slightly
nolimit182
do you think thats enough power or should i get a more powerful amp?
Rob315
"yes it should work fine the amp will give close to 300amps while driving its rated at 350 for 14.4 volts get a ported box or make one if you want deeper bass"
300watts not amps...i know what ya meant but i just wanted to make sure he got what you were saying.
