Amp Installation Location... Suggestions?!?!
Username: Chada08
Post Number: 33
I'm gettin my system installed soon, was wondering anyone's opinion on location for the amp - either back of the box, or back of the seat. I've heard it's bad to put it on the box because of all the vibration? Don't know if this is true or not. any help / input would be great.
Username: Carguy
Post Number: 1176
Most people install the amp on the back of the seat in the trunk. You can install the amp on the box if space is limited. It should be your last choice though.
Username: Chada08
Post Number: 34
Ok, that's what i was thinkin, thanks.
