Phoenix Gold Tantrum (T500.2) ... how stable at what load?
Username: Themax96se
Post Number: 48
Here is the specs:
2 Channel 500 Watt Tantrum Amplifier
Amplifier Type: 2-channel
RMS Power: 125W x 2
Bridged RMS Power: 500W x 1
THD at Rated RMS Power: n/a
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 20-20,000 Hz
Thermally Efficient Heatsink
Timed Acoustically Integrated Muting (TAIM)
Differential RCA or Speaker Level Inputs
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
18dB / Octave High Pass or Low Pass Crossover
40Hz to 800Hz Continuously Variable Crossover Frequency
Auxiliary Outputs Route Inverse Crossover Signals
Variable Twin-"T" Bass EQ Circuit Provides Up to 18 dB of Boost at 45 Hz
Optional RMD Remote Monitoring Display Port
---2 Ohms Bridged / 1 Ohm Stereo Stable
I dont understand these specs. I am used to seeing the power ratings at different ohms.
What does the last spec mean?
1 ohm stable per channel?
2 ohm stable each channel? How much at 2 ohms per channel?
I think its 125wRMS x 2channels @ 4ohms.
I heard these amps are underrated though, and some reviewers said they ran thier Alpine 12" Type R's with them. I am trying to decide if I should suggest this amp for my friend to buy at the pawn shop for $140 to run (2) 12" Type R's, which I read a review for it to be ok. I am just concerned it will not be enough power. Also wondering why they discontinued this model so soon, or if that should even be a concern in the car audio industry.
Ultimately, will this be enough power for the R's?
Post Number: 51
Anyone have experience with these?
Post Number: 53
Bump... any know? I am trying to make a decision on buying one of these!
Username: Carguy
Post Number: 1123
Hey LouieV, from the reviews I heard, they're suppose to be pretty good. However, for some odd reason, no one's listing any spec at 2ohms nor 1ohm. That sounds fishy. I know the manufacturer listed 2ohms and 1ohm stereo stable, but even those guys aren't listing it.
This holds true for most amps. If an amp offers 125W @ 4ohms, then at 2ohms, it is around 200-250W, and 400 - 500W @ 1ohm.
I don't like manufacturers that do not list SN ratio, Damping factor, slew rate and THD @ full power.
Zapco, older Orion and PPI amps list them. Without those numbers, it's not easy judging an amp.
I have a Jensen amp that sounds great and can take all kinds of abuses. However, compared to higher end amps, you can hear the difference in sound quality.
Post Number: 54
Ok I just got this amp today, something happened in the process and I blew a raidio fuse which I replaced. However, my HU (Pioneer deh-25) is STILL NOT WORKING! I am trying to fix this problem now.
Does anyone know about these amps, or more importantly now, might lead me in the direction to get power to my head unit?!?!
Post Number: 60
Loose remote wire, blows fuses. Going to retest the t500.2 soon on the Type R's
