What Jl Audio amp configuration could I use for 2 12" W3v2's
Username: Surfer6099
FL
I have been saving up and I dont know what to do audio system wise. I was looking at the 12" w3v2's but they are 300w RMS and I dont know what Jl Audio amp i would run on them. I was thinking that a 500/1 would be good for each or a 1000/1 but thats expensive and I think that would be pushing to hard. What JL amp do you think I should use and what other Jl Audio subs and equipment do you recommend.
Username: Audio_fanatic
Mukilteo, Wa
Post Number: 24
if you are plannin to get those subs, tha jlw3v2's then a 250.1 amp for each one would work just fine. But i would recommend instead of gettin 2 of those and two 250.1 amps for them, to get one w6v2 and get a 500.1 for it.
