Silver Member Username: Iamduff_87
Michigan
America!
Post Number: 331 Registered: May-04
Posted on If you two amplifiers would you need the combined fuses rating at the battery fuse for the wire. Example. You have Amp A = 50amps Amp B = 20amps Need a 70amp fuse as close to the battery as you can on your positive wire. |
