Dual sealed box
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 178
I have 2 15" Kicker L7's in a sealed box with seperated chambers. Would there be any advantage in taking the divider out?
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 412
I perfer using a box with a divider. If one of your subs happen to be a little off, or one blows it will cause problems for the other sub. Not to mention I don't know of any advantages of running them both in the same enclosure.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7364
no real advantage to sharing air space.
just makes the box easier to build.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 180
The guy at the stereo shop told me that I would gain about 2-3db without the divider. I thought he was full of it. Thanks for clearing that up. He is also the same guy that built me a dual vented box that sounds like crap. $400 waisted cause now I'm back to my sealed box which sounds better. (not as loud though) Thanks.
Username: Araknid
BOCA , FL U.S.
Post Number: 186
you paid him $400 to build you a box?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 188
Yeah. It was 8 cubes and carpeted nicely. I didn't have time to make a box. The only problem was that it was tuned too high and sounded bad. It's now a $400 paper weight.(for a big piece of paper)
