Power distro question...
Username: Jmloughrey
Farmington, CT
Post Number: 811
Just was thinking about my new system, How would i wire up 2 amps and a cap? (dont go into the HO alternator...) Also, on the distro block, would i have to also fuse each power wire after the block as well? its just the cap part that confuses me. Thanks guys...
Username: Hdubb
Farmington, Nm Usa
Post Number: 350
i think if you get a dist. block that is fused then you dont have to worry about fusing the outcoming wires. im not sure how to do the cap. i have never messed with one...yet.
