Y ADAPTER
Username: Eclipse2005
Vicenza, Vicenza Italy
Post Number: 32
Should i use a Y Adapter to wire my sub amp to the heaud unit sub output RCAS? How does it work? And what is better or what is not?
Username: Carguy
Post Number: 1079
What are you trying to do? How many rca cables does your HU have? Some have 3, one for the front, rear, and sub.
Why do you need a y adapter if you already have a sub rca on your HU?
Post Number: 33
i have already 3 but someone told me if i connect both subwoofer output on the head unit (left and right), combine them with a Y adapter and wire the amp just on the left RCA the signal is better. One RCA wire and not 2. What u think?
Username: Carguy
Post Number: 1084
Nah, don't do that. If you already have 3 rca preouts on the HU, use it. The Y adapter is for jbl amp.
The HU's with sub out, use that. If not, you can use the rear outs for the sub amp.
