Treo Engineering
$OAGER$
Does anybody here know if Treo Engineering makes good subs. I would really appreciate any opinions on this brand or MMATS subs. THX
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1210
both brands are way up there with adire, RE, ID, eD, shocker, DD, diamond, etc...
good stuff :-)
$OAGER$
Thank you, so you would recommend treo for alot of bass, exe, if I put two 15" I believe they are called SPX in my crew cab, would they really hit hard?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7325
yes and yes
Username: Zacdavis~
Post Number: 438
Username: Jesuspunk25
Post Number: 13
the stereo guy here in town has 1 15" treo and has knocked pictures off people's walls by driving by.
