MTX....MXA4002 or Audiobahn A8002T
Username: Knockinbme757
Portsmouth, Va
I have two Audiopipe 12" 4ohm DVC 375rms 750peak each.. and i'm stuck deciding which amp would serve them best... i found that i can get the a8002t for 179 and the mxa4002 for 237 which is better?
Username: Carguy
Post Number: 1047
Hey TJ, there's not much difference between the two. 8002T is 2x the power of MTX and it comes with remote bass control for $149 @Eclectric Mart.
As for MTX, they amps are normally underrated so you'll get more than the numbers stated.
I personally tested 8002T amp and it performed fairly well.
I wouldn't pay $237 for MXA4002 amp though. That's way over priced. It should be somewhere close to 8002T's price.
Portsmouth, Va
Thanks... how to i get to Eclectric Mart.. Do You know of any better amp that will power two dvcs 375rms 12's
Username: Carguy
Post Number: 1048
On eBay do a search for Eclectric Mart and you'll find it.
Just about any amp will power those 2. If each sub is going to be powered by separate channel, then look for 2ohm stable amp at stereo mode. If you decide to run both with one channel, then look for 1ohm stable mono amp that's around 800W rms. Just stay away from Pyramid/Boss/Lanzar/Sony.
