WHAT AMP Audiobahn AW1508T
Username: Taylor17
Kopperl, Texas
Post Number: 44
What ohms are they and are they dvc. Also what is the rms for them? I don't think that amp is big enough!
Username: Taylor17
Kopperl, Texas
Post Number: 59
If they are 2 ohm dvc, and are 2000 watt's rms you will need an amp that puts out around 4000 watt's rms times 1 at 4 ohm's. I don't know an amp that big of hand sorry. What is the specs for that 1300 audiobahn?
Username: Jonathan_f
GA USA
Post Number: 2970
Too expensive, you won't find a decent amp that will power those subs without paying thousands of dollars. If you were to spend all that money to power those subs, you'll eventually wonder why you did in the end with the results you'll get. Those subs are heavily overrated and inefficient. The cheapest good $300 amp that is powerful is the JBL 1200.1, so you'll need subs that work around that.
