Splitting Remote Wire
Username: Malby7
Post Number: 124
A lot of you guys have several amp setups. I need to split a single remote wire to go to both amps. I was just wondering what you guys have done in your installs. Do they make a "y" split 18 gauge connector piece? Let me here it guys!
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7253
for just two amps, yeah you splice the wire and split it to both remote triggers.
very simple.
if you're driving more than about 3 devices from one remote trigger though, you use a relay to boost signal current so you don't overload the driver circuit in the head unit sending the 12 volt signal.
