I building a box
Username: Perrydog
Flint, Michigan USA
Post Number: 12
im off to build a bow what would be the best type for 2 kenwood kfc 3005 and what direction make them face and cone in or cone out for loudest bass, all suggestions welcoea
Username: Themax96se
Post Number: 30
Do you already have the arrows for your bow?
dummy
bow, that's the front of the boat and that last post was rather stern..
Username: Perrydog
Flint, Michigan USA
Post Number: 16
i have everything its jsut to build the box now
Username: Perrydog
Flint, Michigan USA
Post Number: 25
umm a box not a boat
Username: Hdubb
Farmington, Nm Usa
Post Number: 281
if this is your first box, iwould just make it a very simple box. probably go 1.25 feet in each chamber. or 2.5 all together. just make it a normal box. then when you get better you can make a fancier box.
Username: Hdubb
Farmington, Nm Usa
Post Number: 282
if your want a ported box go 2cu feet in each chamber. try to find some designs for your box, and look at your spec sheet and try to build according to it.
Username: Hdubb
Farmington, Nm Usa
Post Number: 283
if you want load bass then a vented box(bow)lol is what you need.
