Experience.
Username: Carguy
Post Number: 1025
Anyone have experience with Orion HCCA 250G4 or PPI PCX 4125 amps?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7238
yes.
Username: Carguy
Post Number: 1035
What are your views/test results for both? I'm thinking of buying one of them.
Username: James1115
Ct
Post Number: 162
I have the PPI pcx 4125 Isaac and personally I have never had a ny problems with it and it sounds great. I am running 2 sets of boston acoustic pro 5.25 component sets with it and it is doing its job flawlessly. But thats my opinion I guess.
James
Username: Carguy
Post Number: 1037
I'm also looking at Zapco Studio 500 model. So far those 3 had the best spec.
Thanks for your info.
Username: Glasswolf
Post Number: 7244
For PPI, the only amps they ever made that I drool over are the older Art series models.
The Orion HCCA is a great amp, but only if you can run it at 1 ohm stereo or 2 ohms bridged. Otherwise it's wasted since it's designed to run best at low loads.
The Zapco is a fantastic amplifier. The Studio line is an older amp, but still built with precision and care. Really it's a matter of matching the amp to what you need it for.
between the three if I was given the option to take one for free, just on personal preference, I'd take the zapco amplifier, then the orion.
Username: Carguy
Post Number: 1038
Thanks for the input. PPI was my 1st choice till I saw Orion HCCA, then I saw Zapco and it blew away PPI's spec. I can see why you like Zapco products so much.
Username: Jonathan_f
GA USA
Post Number: 2966
I still wish I had some of the older Art series amps I had, they were fantastic.
Username: Carguy
Post Number: 1041
I heard in the Art series, the ones made on 1996 had .2 technology and was much better than 1992-1995.
Username: James1115
Ct
Post Number: 173
yeah I also have a art series a600.2 and I love it. You can get them for good prices on ebay these days.
James
Username: Carguy
Post Number: 1042
I was looking at that amp on eBay. I wouldn't sell that amp if I were you.
