Jbl vs infinity
Username: Abhinavrishi
Marysville, Wa US
which 6x9 gives more bass...infinity kappa 63.5i or jbl power series...or jbl t595..
Pharoh
I no infinity and they have GREAT BASS and GREAT HIGHS, thats if you buy the right products. If you get an infinity sub, theya re awsome for good bass, if you get a 2way or triaxle, they arent the greatest for bass, they are amazing for highs tho. id go with the 6x9's because they have an expanded cone meant for that little extra bass, I havent heard JBL speakers at all but i do no that for more bass go with a bigger speaker.. :-), If you really are looking into more bass, you could even buy a self powered bass tube, 8 sich is fine for what you are looking for probobly, they sound great for just the little entertainment. that way its alot easier and no fuss with an amp etc. unless ur looking for sumthingelse off topic.
