Just out of curiosity
Username: Bassfreak596
Post Number: 67
overall which ones better ?
Brahma or Eclipse Ti ?
i own the Brahma but never heard an Eclipse Ti actually playing.
Username: Pharoh
Bradford, Ontario Canada
Post Number: 15
They are both very good, but i still like Brahma.
Username: Taylor17
Kopperl, Texas
Post Number: 75
Just my personal appenion, I really like the Eclipse T's. I would kill for a pare of the Eclipse T pro 18's!
Post Number: 68
does the xmax matter that much ?
the Eclipse Ti shows 1.5inches of xmax while
the Brahma has 29mm which is approx 1.142inches !
does this mean that it has a hand over it ?
Brahma is a great sub no doubt. Will the Eclipse Ti beat it because of greater xmax ? more displacement ???
Post Number: 69
i was planning to get another sub.
Eclipse Ti a better option ? or all of the same league ?
the brahma is backordered for the next 6weeks !!
Username: Hdubb
Farmington, Nm Usa
Post Number: 296
i have made my brahma throw for more than 1.1 inches easy its more like 2.7 inches
Username: Hdubb
Farmington, Nm Usa
Post Number: 297
they are both great subs though. i like the brahma because i have one, but im sure there isnt much if any on the spl or sq of both these subs. the only difference is the price.
Post Number: 70
hifonics 1000w mono amp good for 1 Eclipse Ti ?
Username: Hdubb
Farmington, Nm Usa
Post Number: 299
it would but look into a orion1200d or the hifonics brutus bx1500. i think these hifonics amps are oveerrated so get something with a little more power, its like 40 more dollars. i was told by a wolf that cadence also makes good cheap amps or jbl
Post Number: 71
thanks mun !
(jamaican style.. heh)
