Jonathan or Glass "Tweeter Placement"
J. Johnson
Without damaging the stock look of my car. I would like to install my kappa 6.5 mids and tweeters into the stock 6x8 location. Will the tweeter sound okay installed under my door panel next to the woofer. or should I put it ontop of the panelling. I figure multi-element speakers are mounted like this, so it will be okay for my good components. Thanks in advance.
