Need some help on my wiring
I have 2 12" Audiobahn AW1251T's hooked up to a Kicker KX600 x 1 Amp. I have them wired in a parallel...and one of them hits harder than the other! Can anyone help me out on this?
Username: Taylor17
Kopperl, Texas
Post Number: 11
Maby it is the boxes, are they exactly the same? Are they sealed or ported?
Username: Dut4
they are in single boxes and both are sealed and are the exact same
Same speaker wire? Good solid connections? Try swapping the subs in the enclosure. See if you have the same sub is still hitting harder, or see if the same side is hitting harder. Or it could clear up the problem!
Username: Dut4
alrite we'll do and see how it works...thanks for the suggestion!
