Jugernaut...
Username: Killer44
Ontario Canada
Post Number: 47
im planning on buying a 12 inch mmats jugernaut
1400 Wrms real world power!Custom cross-drilled forced air induction for maximum voice coil cooling.Quad stacked spiders to handle extreme excursion.3" diameter dual aluminum voice coil.
or a dreadnaut(1000wrms) what type of amp should i use to power these>>? and could i use the same custom box for my 12 inch mmats pro series for either of these?? thanks in advance...adam
Username: Hdubb
Farmington, Nm Usa
Post Number: 225
how much are you looking to spend on an amp? i saw your box but i dont know how big it is? it needs to be pretty big. look at the specs of both and it should tell you the recommended box size.
Username: Killer44
Ontario Canada
Post Number: 48
like around 300$,,,,
Username: Killer44
Ontario Canada
Post Number: 49
anyone know what i could power either of them with?
Username: Killer44
Ontario Canada
Post Number: 50
there gotta be someone out there that know what would be a good amp for these subs????/lol
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 125
for the juggernaut i would have to say a hifonics 1500d and for the dreadnaut a hifonics 1000d. and for the box hunter is right it depends on the size of the box. Does it match the specs to the juggeranut or the dreadnaut
Username: Killer44
Ontario Canada
Post Number: 51
not sure havnt checked it out yet but u think i would have to upgrade my charging system...like get a new alternator....or should it be able to handle that much>,,,,
Miami, FLORIDA USA
Post Number: 126
it depends on your ampere of you're alternator. How mny amps is your alternator
Username: Killer44
Ontario Canada
Post Number: 54
not sure all i know is that its a 1994 ford probe gt...how would u check the amps>>>/
Miami, FLORIDA USA
Post Number: 128
at a local shop like pepboys or someshop of that sort. Did you buy it used or new, because if you bought it new than most likely it is a stock alt. So yeh to be on the safe side i would upgrade the alt. BUT you'll never konw until you get the alt. checked or until you install the system to see if the lights dim.
Username: Killer44
Ontario Canada
Post Number: 55
do u have any idea what the price range is to to that(alt. upgrade)?...
Username: Hdubb
Farmington, Nm Usa
Post Number: 233
like 150 up.
Username: Killer44
Ontario Canada
Post Number: 58
kk thanx alot for the help guys...going to hockey now but will get back to ya on the updates...peace...
Username: Fordpwr
Los angeles, Ca Usa
Post Number: 77
hey killer i dont want to put anyone down here but i would try something else before settling down with the hifonics, either 1500 or 1000. i had the 1500 for 2 weeks and i'm telling you it sure didnt sound like it was putting all its advertised power.with the same sub and impendance, i tried the mtx 1501 and the infinity 1210a and these amps rocked the sh1t out of the hifonics!!!!!! Try other forums and asked around. i did a little research after buying mine. almost everywhere i checked people said that they don't put out all their advertised power...? all i'm saying is give other amps a try before settling down with the hifonics.its cool loking but thats about it. see ya.
Miami, FLORIDA USA
Post Number: 129
yeh tats why i reccommened the 1500d frp the uggernaut. THe juggernaut is 1400w rms. and the hifonics says its put out 1500 at 1 ohm which is over rated. SO i reccomended it because itll put out around 1200-up which is fine for the juggernaut to reach full potential
