Username: Erik123456 Arlington,
Tx
Post Number: 315 Registered: Aug-04
Monday, January 03, 2005 - 05:55 GMT will the 342 be a good match for my eclipse components (rms 125) it puts out 130x2 at 12.5 volts 2 ohm and will the 801D be a good match for my 1 eclipse ti 12" (rms 750)
Tx
Post Number: 316 Registered: Aug-04
Monday, January 03, 2005 - 17:51 GMT anyone?
Username: Lbeckner Tulsa,
Ok
Usa
Post Number: 141 Registered: Oct-04
Monday, January 03, 2005 - 20:02 GMT Sounds just right. Happy listening.
Ok
Usa
Post Number: 142 Registered: Oct-04
Monday, January 03, 2005 - 20:06 GMT Wait. I take that back. Your components are probably 4 ohm. That means that you will only get about 60w x 2. Goto MTX.com and see. I would try a bigger amp.
Tx
Post Number: 317 Registered: Aug-04
Monday, January 03, 2005 - 21:04 GMT how can you tell what ohm the components are - eclipse didnt have the specs in their brochure or website...
Ok
Usa
Post Number: 146 Registered: Oct-04
Tuesday, January 04, 2005 - 02:06 GMT Standard impedance for components is 4 ohm. Not on website? Thats wierd.
