Pioneer DEH-P7600MP
Username: Sublime420
Ca Us
Post Number: 28
is this HU any good?
Pioneer Head Unit
I have that head unit and its great. It has all the features you need to adjust your audio, and it sounds great. Also has subwoofer controls with the crossover and crap like that. I recommend you get it. You sould be disapointed.
Pioneer Head Unit
**you shouldn't be dissapointed.**
Username: Hassan
Post Number: 28
i would also say go for it i have the same one but without the mp3 player its great by the way where r u getting yours from becouse i saw it for preatty cheap on sounddomain
