Will this be enough?
Username: Ginuwinepz
Post Number: 29
Would a Kicker 600.1 be enough to power 2 kicker comp vrs? 15" if not what should i get that is around $200-$300 or less. I am shopping on Ebay.
Post Number: 31
any opinions would be appreciated, thank you
Username: Jmloughrey
Farmington, CT
Post Number: 648
should be fine...
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6760
they can take a bit more than that but the 600.1 should be fine.
Post Number: 33
Well, i would like to get as much power out of them as possible, if you know of any amps that would work better, that are maybe a little cheaper amp, but put more power to them let me know, thanks!
Username: Djeter108
IN USA
Post Number: 45
JBL GTO 601.1 - $350
Username: Ahmer
Hyderabad, Sindh Pakistan
Post Number: 8
Username: Erik123456
Arlington, Tx
Post Number: 278
dont pay 350 for the 601.1
you can get the 1201.1 for 289 on ebay brand new
get a jbl bp 600.1 for like 120-150 and you will be fine or the kicker 600.1
