Hey Yall How did your self carpeted boxes turn out?
Devon
just got done with my box for a single 12"...1.25 cu ft sealed... i went to lowes and got some 3/4"by3/4"x4ft angle aluminum and covered all the edges of box looks sweet kinda rugged...just trying to give some ideas for those who arent good at carpetting boxes the christmas present way. the aluminum covers up all the staples and seams. you could even paint the angle aluminum
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 52
thats cool il try that with my box
i made a sub box for 2 12's isochambered and i wraped it in black vinyl with spray adhesive but the edges look ruff i bet that would clean it up
Username: Koz1031
Monticello, In United states
Post Number: 343
nice idea. Wonder what that would look like covered in leather with the angle aluminum. or even steel as far as that goes, made to look old. Hmmmm ideas are comin to mind now. starting to get a new idea for the van.
Thanks Devon.
Username: Jmloughrey
Farmington, CT
Post Number: 668
i still say somebody glue pennies around the box on all side except the bottom and back, glueing pennies on stuff rules...or duct tape the hwole thing...
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6925
no way.
just build a box for a pickup and hammer beet bottle caps into the whole entire box.
that'd be sweeeet.
it'd match the door frame of the doublewide!
Devon
it looks awesome you can even get some steel wool and give it the brushed look...
Devon
some tips on it use a hack saw to cut it dont attempt to use snips..and also use the plastic guide used to cut trim so you get perfect 45 degree angles and pre drill holes before you screw it on...one more thing before you drill holes in it its better to take a nail and hammer and make a dent so the bit starts and doesnt run all around the aluminum.
Username: Rzarector
Post Number: 54
i have a bunch of shell casings i picked up from a gun range too hmmm
Devon
maybe you could cut them so you only have 1/4 inch from the back..then glue them on to mounting screws of subwoofer.
Username: Iamduff_87
Michigan America!
Post Number: 302
or you could just leave it wood and carve out designs in it with ur whittlin knife.
Michigan America!
Post Number: 303
or cut up bud light boxes and tape them on the whole box. ive seen hats made like that. good ole country boys
Username: Zacdavis~
Post Number: 406
heres another.....lol
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 115
datz tight work
