Too much power?
bid
I'm looking at using a 4 channel amp that passes 220 x 4 at 4 0hm.
MY front speakers are infiniti kappa 3 way coaxials.. 75rms.. and i have an audiobahn single 12 inch sub that can handle 400 rms..
if i use this amp.. will it be too much for the speakers? And can i bridge the remaining two channels to power the single sub?
thanks in advance :-)
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6892
"220 x 4 at 4 0hm"
what make/model amke?
is that an RMS power rating or peak/max?
If that's a class AB amp and an RMS power rating, that amplifier is going to be drawing over 100A of current at full output at 4 ohms. more if you bridge two channels to that sub. that amp would be massive.. probably over 2 feet long with active cooling.
