Glasswolf need advice
Username: Aaronoberste
im putting 2 10 inch jl ,in my truck, they're rated 125 watt continious power handing,,the available conf is 4 - 8ohms, they're single voice coil,i was wanting to get a jl or mtx amp ,how many watts should i be looking for, and should i only be looking @ the 4 ohm watts and not the 2, thanks for all the help.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6776
for two of those subs, you'd want the 4 ohm SVC versions.
that'll be a 2 ohm load on a mono amp.
you'll want an amp rated for 250 watts RMS x 1 @ 2 ohms
thank you
