Will a single re se 15 hit harder than 2 adire shivas?
giturar
run from a jbl bp1200.1 amp
Username: Jmloughrey
Farmington, CT
Post Number: 640
no real way to tell actaully, if you run 2 shivas from that amp you'll void your warrenty, you could effectivly run 4 shivas with that amp :-)
Has alot to with the box's available, the shivas would move more air, even with the large xmax on the re sub....
