You might laugh at this one
can u get a 4ohm svc to run at 2ohms to the amp without gettin a second 4 ohm sub. hah its prolly stupid to ask
Username: James1115
Ct
Post Number: 54
NO
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6746
no but what you can do is use a 2 channel amp bridged.
that'll give full power from the amp to a single 4 ohm load
Username: Jmloughrey
Farmington, CT
Post Number: 638
they answered your question but i thought i'd go into alittle more depth about why, your sub is rated at 4 ohms. Ohms is a level of resistance off the voice coil (in this particular case) Its a set resistance, its just how its made, itd be like asking, is there a way i can turn an apple into an orange? Thought that might make you understand a litlte better.
Username: Langless28
Post Number: 51
hahah thanks
