Kove Audio
Foxstoner0420
I have 2 12 inch Kove Audio KMG K Pro Series subs. Has anyone ever heard these or know if they are any good. I heard them when i bought them but he only had a 300 watt amp pushing them both. Does anyone have any experience with Kove. Thanks
Username: Jmloughrey
Farmington, CT
Post Number: 645
kove, good stuff, now kole audio...bad bad bad...you'll enjoy those Kove subs, not sure on the RMS but feed them whatever they want for power and you'll be extremly happy. make sure to put them in the right box as well
foxstoner0420
Right now they are in a Sealed box. The dimensions are L-30inches x W-15.5 inches x D-15 inches. Does that sound right?
