Question about imaging
drb
If i was to make a speaker adapter for a 6.5" to go into a 6 x 9" hole, would it help or hurt the imaging to also mount the tweeter on the board with the woofer? Also does anyone have any component recomendations. I want something that is not quite as bright as the infinity perfects, but a little snappier than the Dynaudio 240gt. I am looking for something at or below $600 retail and around $450 on ebay.And also that I don't need more than 100 watts to push it. Thanks
Username: Jonathan_f
GA USA
Post Number: 2789
Try the Adire Audio Kodas, and also the Diamond Audio Hex series with silk tweeter. Great sets, with a good bit of kick to them.
